Motor oil in coolant?
Old Oct 26, 2011 | 02:12 PM
1arock's Avatar
Default Motor oil in coolant?
About a year ago I replaced my injector cups due to a fuel in coolant issue. This also caused all the rubber hoses to turn soft needing replacement. Now it appears motor oil is getting in the coolant, could the orings in the oil cooler be the problem, head gasket, injector orings? I does seem to have developed a little miss or stutter when idling. What is most common? I am thinking the oil cooler because I know it has orings that were subjected to the fuel bath that softened all the other rubber in the coolant. Any heip would be appreciated.Rocky
2002 F350 PSD
Old Oct 26, 2011 | 06:11 PM
fordornothing's Avatar
could be cracked injector cups, again. or bad injector o rings. wehn you replaced the cups did you do all 8 or just the bad one? did you replace the injector o rings? i haven't heard of the oil cooler o rings going bad and causing oil in the coolant.
Old Oct 26, 2011 | 06:21 PM
1arock's Avatar
Yes I did all 8 of them and used all new injector o rings.
Old Oct 26, 2011 | 06:56 PM
did you use ford injector o rings?
Old Oct 26, 2011 | 07:56 PM
1arock's Avatar
I used orings and cups from the local Navistar truck dealer.
Old Oct 26, 2011 | 08:35 PM
CSIPSD's Avatar
Its your oil cooler...
with cracked cups you get fuel in the coolant, with a cooler issue you get oil in the cooler...
Its a messy job but not bad.
Old Oct 27, 2011 | 02:03 PM
1arock's Avatar
Thanks guys, could it be o rings or is the cooler prone to failure?
Old Oct 27, 2011 | 07:03 PM
probably just o rings.
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Rayrock4
Aug 30, 2015 09:45 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
