cummins smokes blue
Old Oct 23, 2011 | 10:12 AM
94cummins12v's Avatar
Default cummins smokes blue
ok heres my problem guys i have a 94 cummins 12v engine was rebuilt around 2 years ago has smoked blue eversince done a compression test and blow bye test both check good injectors have been tested and no issues. i hav even ran back to stock injectors and no improvement. if i run the grid heater there is alot les blue smoke. and the warmer the day less smoke yet. when i drive it the smoke usually goes away after a mile or so but when its cold and it idles you can still slightly see it. today i pulled the turbo and exhuast manifold and conformed it is only the 3rd cylander any thoughts?
Old Oct 23, 2011 | 11:05 AM
daveO's Avatar
Valve seals?
Old Oct 24, 2011 | 11:06 AM
could be the exhaust 3 valve seal isnt sealed but neither is exhuats 4
Old Oct 24, 2011 | 05:31 PM
6btDakota's Avatar
Mine does that too. I am blaming it in my unknown-but-retarted-for sure timing after gear tooth jumping attempt.
Old Oct 24, 2011 | 06:19 PM
nope timing aint it
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Wigginsmk
10
Jun 2, 2015 08:06 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
