6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
updated PCM and TCM codes?
Old Oct 21, 2011 | 07:46 AM
99stackedpowerstroke's Avatar
Default updated PCM and TCM codes?
so i looked under the hood of my truck and was wondering for awhile about this and just got the chance to get back on here but it says the PCM and TCM were updated then it had these numbers under it, 3U7A-12A650-FTG on 3/06 dealer number 20018 and change authority 06E17 any info on this would be great guys!!! thanks!!!!
Old Oct 21, 2011 | 08:18 AM
Mdub707's Avatar
3U7A-12A650-FTG <-- I believe this was just the newer flash at the time that got rid of the inductive heating flash, so that the injectors buzzed when you first turn the key, opposed to when you shut the truck off. I believe the TCM just happens to be part of this flash... I think everything actually gets flashed when this is done, the ECM, PCM and TCM.
The 06E17 was a recall kind of thing for the EBP (exhaust back pressure sensor). I don't recall exactly what it was about but found this... Emission Recall 06E17 on 2003-2004 6.0L Powerstroke - Diesel Forum - TheDieselStop.com
Sounds like both of those are pretty old and were more or less mandatory on the 6.0's. Nothing to worry about, they were just "newer" flashes Ford had.
Old Oct 21, 2011 | 09:50 AM
okay i wasnt worried just wanted to check on stuff thats been done to the truck, is there a newer flash that should be done to the truck to make it last longer and perform better or is everything else thats newer basically the same and not worth reflashing?
Old Oct 21, 2011 | 10:23 AM
Mdub707's Avatar
As long as your injectors buzz when you first turn the key to start the truck and NOT when you turn the key off, I wouldn't worry about any updated flashes. If it buzzes when you turn the key off, go get the flash. According to those numbers you posted, you're ok though, just run what you have. Stay on top of oil/filter changes and fuel filters.
Your sig doesn't say anything about a coolant filter... it'd be about the same price as getting an updated flash... might want to look into one.
Old Oct 22, 2011 | 10:36 AM
ya im getting a coolant filter and oil filter bypass after i get my gauges installed, im ordering my fuel pressure today, how often on fuel filter changes? and i can get an updated flash prety cheap my friend is a mechanic at a ford dealer bout 30 min away
Old Oct 22, 2011 | 02:54 PM
Mdub707's Avatar
I usually change my fuel filters about 5k-7.5k miles.
Old Oct 24, 2011 | 10:44 AM
okay thanks
