control arms
Old Oct 16, 2011 | 07:35 PM
01ram2500's Avatar
Default control arms
any one know where i can get adjustible control arms ? I have seen then for as much as $900 that is a little much if ya ask me . on a budget 2 1/2 leveling kit
Old Oct 16, 2011 | 09:29 PM
NadirPoint's Avatar
Why adjustable?
Old Oct 17, 2011 | 11:53 AM
1AMatt's Avatar
Site Sponsor - 1aauto
You can get away with stock control arms with a 2.5" kit. It doesnt hurt to get some after market ones. You dont really need adjustables unless you plan on going higher one day.
Old Oct 17, 2011 | 03:33 PM
01ram2500's Avatar
some people that i have talked to said that they would put the axel back where it belongs. I am not going any taller it rides rough enough now, with no load dont want to make it any worse , besides I dont want to deal with getting a modified sticker here .
Old Oct 17, 2011 | 07:25 PM
NadirPoint's Avatar
That's correct. Even with just 2" lift and the lower eccentrics full forward, the axle will be pulled towards the rear and some tucks may not be able to achieve correct caster alignment depending on the type of ball joints installed. I just installed a set of Thuren's arms and can't say enough good about them. You can see the difference in where the axle sits in the before/after shots:
http://stuff.is-a-geek.net/PhotoAlbu...ics/CRD_46.JPG
http://stuff.is-a-geek.net/PhotoAlbu...ics/CRD_85.jpg
Huge difference. Truck finally handles and steers as it should. I would view any adjustables as just something else to come loose and break.
Old Oct 17, 2011 | 08:47 PM
01ram2500's Avatar
I dont think that thuren's makes them for my truck .
Old Oct 17, 2011 | 08:53 PM
NadirPoint's Avatar
No, starting at 2003. But the point being you really should install proper length arms to maintain the correct front end geometry wherever you get them from, for any lift. The front ends on these trucks work great, but only when they are properly maintained.
To this I would say, no, it really "helps" quite a bit:
Old Oct 18, 2011 | 03:49 PM
01ram2500's Avatar
my truck drives kinda funny, at first i thought it might be ball joints , not that well then wheel bearing , not that eather ,replaced all front tie rodends, draglinks , even had track bar checked when i put new tires on everything was good.
burndiesel
10
Feb 7, 2023 01:15 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
jdnetx
Jul 2, 2015 07:38 AM
Jun 4, 2015 08:40 AM
