97 7.3 runs rough
Old Oct 9, 2011 | 07:24 AM
tim white's Avatar
Default 97 7.3 runs rough
my 1997 Ford F350, starts and runs fine for a few seconds, then starts missing bad. I can shut it off, restart, runs fine and starts missing again. HELP
Old Oct 9, 2011 | 10:37 AM
95powersmoker's Avatar
Some more info would really help us out...
How many miles?
Do you have access to an Auto Enginuity scanner?
Old Oct 9, 2011 | 11:19 AM
tim white's Avatar
240000miles and no, I don't have access to an Auto Enginuity scanner. Everything on the truck is original. The only thing I changed was the alternator.
Old Oct 9, 2011 | 11:23 AM
Without a scanner, it's going to be a tough thing to diagnose.
You need to get it running and check fuel pressure... Also, before you start it, check the oil level in the HPOP reservoir. Then after it dies, check it again. Make sure your oil level in the crankcase is full.
If all those are in good shape, It could be uvch's or injectors...
Old Oct 9, 2011 | 08:36 PM
tim white's Avatar
thank you for your quick reply i check the hpop and it is full i did not check fuel pressure yet ran out of time let you no what i find out thank you tim
Old Oct 15, 2011 | 01:57 PM
strokedout96's Avatar
take the fuel pressure regulator off and clean out the little wire mesh screen.
bdbfam
Aug 31, 2015 09:06 PM
mhoos
Ford Excursion 99-05 7.3L and 6.0L
Jul 28, 2015 09:31 AM
BYRQN33
Mar 18, 2015 04:12 PM
UniqueCopy
Dec 14, 2014 11:37 AM
BCFseries
Oct 28, 2014 08:46 AM
