Daytime Running lights
Old Oct 8, 2011 | 11:25 AM
95powersmoker's Avatar
Default Daytime Running lights
Did some of the superduty's come with DRL's? The truck I went and looked at the other day had the headlights on after I started it but before I physically turned on the headlights... Is there any way to disconnect that so they just come on with the headlight switch?
Old Oct 8, 2011 | 04:58 PM
fordornothing's Avatar
i think they came out with a similar feature in 05. does the switch have a position to the left of center? like you are turning on the dome light in a OBS
Old Oct 8, 2011 | 05:05 PM
I don't believe it did, I think it just turned to the right.
Old Oct 8, 2011 | 05:20 PM
huh. i haven't heard of that on the older SD's. so the headlights were actually on? someone might have messed with it in the past. the dash piece around the gauges and the headlight switch just pops off. don't pry to hard tho, it's only plasctic.
Old Oct 8, 2011 | 10:15 PM
Yes the headlights were on even though the switch was pointed straight upwards... This one doesn't pull out because it doesn't have the fog lights...
Old Oct 8, 2011 | 10:47 PM
i think it only pulls out in the far right position on the older SD's. that's how mine is. i don't have the lights in the bumper. but i do have plug right behind the drivers headlight. it might have it there.
Old Oct 11, 2011 | 11:14 PM
CSIPSD's Avatar
It was more then likely from Canada... I had a 95 OBS from Canada back in the day with the DRL... Loved it. You can disconnect the moduel, IIRC its on the drivers side fender.
Old Oct 11, 2011 | 11:16 PM
Joe! What do you think?
Old Oct 11, 2011 | 11:28 PM
CSIPSD's Avatar
You need to check it out...
"needs some work (glow plugs)"
Can be code for "Hard start when cold because of" - injectors shot or low compression or low/no fuel pressure or bad hpop... and so on
Old Oct 11, 2011 | 11:32 PM
It started perfect the other morning when it was plugged in... I'm thinking glow plugs and a relay are in order.
If I picked it up, I would swap my injectors into it...
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
carid
Jan 6, 2015 06:28 AM
bypass-21
Jan 3, 2015 04:47 PM
carid
Nov 10, 2014 02:15 AM
