Another axle swap
Old Oct 4, 2011 | 08:05 PM
97dieselnewb's Avatar
Default Another axle swap
I've got a 97 f250, I found a dana 60 out of a 95 f350... Same gear ratio as my truck... It comes with everything... Track bar and sway bar and all the brackets... Complete hub to hub... Any trucks or tips... Or heads up?
Old Oct 4, 2011 | 09:07 PM
joebob3093's Avatar
Moderator
its pretty straight forward. the only trouble i had was getting the trac bar to line up. we had to build a drop bracket for it. i didnt worry about hooking up the swap bar.
Old Oct 5, 2011 | 06:57 PM
fordornothing's Avatar
when i did this on my 94, i had to drill for the sway bar brackets. it's really not hard at all. just a little time consuming.
Old Oct 10, 2011 | 03:10 PM
Will I run into an problems with the drive shaft? I heard some people had to shorten theirs a couple inches....? If that was the case would it be safe for all the parts to be driven with out a front drive shaft, so I could get her down to the drive shaft shop
Old Oct 10, 2011 | 07:23 PM
oh right. i forgot about that. the 250 just has a single u joint on each end. the 350 has a double knuckle deal on one end. it worked fine for me because i had a t case out of a one ton in it already. but to answere your question. yes. it won't hurt anything.
Old Oct 10, 2011 | 07:51 PM
joebob3093's Avatar
Moderator
Default Re: Another axle swap
I never had that problem. But don't hook up the drive line and drive it you will be fine.
Old Oct 12, 2011 | 11:26 PM
^ why didn't you have that problem did younger an ae from the same year or how did you go around the problem?
You get an* not younger an
Last edited by 97dieselnewb; Oct 12, 2011 at 11:26 PM. Reason: Automerged Doublepost
Old Oct 13, 2011 | 02:25 PM
joebob3093's Avatar
Moderator
my pickup is a 95 the axle i used is from a 96.
Old Oct 13, 2011 | 06:47 PM
there must be a difference between the 94 and 95 drive shafts then... my axle was from a 96 too.
Old Oct 13, 2011 | 07:44 PM
joebob3093's Avatar
Moderator
also did a swap in my 85, put a 90 axle in it and the driveline went in just fine.
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
Natenelson1
Jan 19, 2015 07:23 PM
KYLEBOY
Jan 18, 2015 06:36 PM
natenel1
Oct 26, 2014 03:09 AM
blakec
20
Oct 18, 2014 03:35 PM
