Tow Haul Mode
Old Jan 9, 2008 | 05:55 PM
A-CFarmer's Avatar
Default Tow Haul Mode
I drove my buddies 06 F-350 King Ranch the other day with his stock trailer on and he asked if I was using the tow haul mode and I said no, and then switched it on. The problem was I couldnt really tell a difference? What exactly does the Tow haul mode do for the truck?
Old Jan 9, 2008 | 07:59 PM
GmcLbz's Avatar
Site Sponsor - Upstate Diesel Performance
Tow/Haul will shift up slower and downshift faster than when not in tow/haul to help get moving and also to slow down. It does work. Hope this makes sense.
Old Jan 10, 2008 | 12:35 AM
2500HeavyDuty's Avatar
It will rev up higher in tow mode and change the shift points to a higher RPM so make the engine work not as hard to move keep the wright moving, and Locks up the torque converter sooner. And it helps a lot when braking because it will down shift much sooner than usual uses the engine/transmission to help slow down so it is easier on the brakes.
Old Jan 15, 2008 | 11:13 AM
Blue01F250's Avatar
Duramax Virgin
Ditto to what they said, and a lot of times, it keeps your OD from being engaged so that it won't burn up from constant up and down shifting...
Old Mar 9, 2008 | 09:52 PM
JON's Avatar
JON
Member
Default Yep
Basically more agressive shift strats.
Old Mar 15, 2008 | 04:47 PM
F250gal's Avatar
What they said.........
I really appreciate my tow haul....
Old Mar 18, 2008 | 12:10 PM
OneTon4Fun's Avatar
The Tow ? Haul mode increases the line pressure of the transmission for a more firm shift, th PCM spreads out the shift points so you runn the gears out at higher revs.
I have a 2003 F350 KR dually and I love the TH mode, the only thing that I have a problem with is the truck will downshift the transmission at times when I don't want it to slow down and the revs junp way up. This the closest thing to a jake brake.
Old Apr 9, 2008 | 02:30 PM
RTL Garage's Avatar
I Notice The Tow Haul Prolongs The Shifting - Keeping The RPMs Up Longer.. On My Buddies 6.0 It Really Does Help Slow The Truck Down.
Aug 5, 2015 04:40 PM
May 7, 2015 11:50 AM
syctaz
Mar 3, 2015 09:23 AM
1997silverado
Feb 6, 2015 11:28 PM
Jan 11, 2015 08:37 PM
