HELP-J35 recall/performance questions
Old Sep 21, 2011 | 03:12 PM
Puck's Avatar
Default HELP-J35 recall/performance questions
HELP! My truck is at the dealer for MIL #2262 (turbo boost) & #0409 (EGR) problems.
I currently have TSB 18-013-008 (p/n #62350430AS) that was downloaded in June 2009 due to the above MIL #s and also downloaded the anti bootloader program as well.
I am more than a little wary of another download which killed 2 mpg, made my exhaust brake less powerful and prevented me from modifying my engine/exhaust.
Does anyone know exactly what changes are made to the ECM when the J35 (TSB 18-024-009) recall/reflash is performed?
I've read everything I can find about the J35 recall, yet no one seems to know exactly what modifications are made to the ECM programming.
"It improves power and mileage." "It runs worse and cost fuel economy", are just a couple of things I have read about the recall.
Lastly and most important will I be able to use a Smarty 67me with this recall? I plan to lose the DPF/egr and increase my mileage.
ps.
My dealer tells me it
will void my warranty
if I don't do the J35 Thank You,
Puck '08 2500 4x4 manual
Old Sep 21, 2011 | 05:35 PM
peters0756's Avatar
Every time I took my 07.5 to the dealer they would do one flash or another and every time my fuel economy (if you want to call it that) would get worse. If you do the deletes and run the programer it will over ride all of the flashes that the dealer uses. you won't be able to use the dealer for ecm issues from then on but in most cases you won't need them.
Mar 20, 2015 08:20 AM
VanGuy
Feb 3, 2015 12:19 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
