fuel filter
Old Sep 19, 2011 | 08:22 AM
Rail's Avatar
Default fuel filter
discussion lately has stated that fuel filters are only sold with the plastic housing. I see on NAPA site that fuel filter for 6.7 is available element and O-ring only, no housing. Anybody use these or is there a better option out there?
Old Oct 4, 2011 | 06:14 PM
jdog78's Avatar
there are sold either way if u havent switched over to the newer style where u can change the elment at less then half the price.
Old Oct 5, 2011 | 09:28 PM
coors_man_2005's Avatar
if you have changed your filter sense it was new all u need is a replacement i run mopar filters but thats just me
Old Oct 6, 2011 | 07:03 AM
Flswamprat's Avatar
I order FleetGuard from Geno's, filter with or without housing, of course thats after I took it up the A$$ (no lube) from the local stealership, I could of purchased it from Geno's for 1/6th of the price
Old Oct 11, 2011 | 07:26 PM
Big Earl's Avatar
Default Fuel Filter
I use the NAPA filter and have no problems.
Old Oct 11, 2011 | 08:34 PM
jdog78's Avatar
i run mopar only,had bad exp. with cheaper paper ones collapsing
Old Oct 27, 2011 | 07:41 AM
Rail's Avatar
I settled on WIX, this is a big trucking town and WIX is their first choice in most autoparts stores. I like the elements, guy made me a deal on buying two elements and two filter/element packages. Geno was out, dang it. Modified the wheel skirt by cutting 1 1/2 inch section next to shock off and filter can be changed without going under truck. I found my old "pump filter pliers" with the long wide jaws for irrigation pumps and they work great removing the old housing. Then underneath for about a minute to attach sensor wire and woop woop done in under 15 minutes. Pop riveted a rubber flap over the enlarged opening so the wheel skirt still does the deed. I change fuel filter at 7500 miles with my oil and filter, what has everybody else been doing?
Dbleo351
Nov 20, 2016 09:34 AM
jeffersonl
Nov 15, 2015 07:35 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
james2562
Oct 8, 2014 06:14 PM
