EBPV Jakebrake???
Old Sep 14, 2011 | 10:55 PM
Travistrent1993's Avatar
Default EBPV Jakebrake???
Is this worth it? Will the pressure in the motor screw anything up?
I got a 5spd and don't really know what people do to wire it to the pedals or a switch
Thanks
Old Sep 15, 2011 | 07:26 PM
fordornothing's Avatar
i did this on my SD and i love it. even in town driving you can really feel it. go to Swamp's Diesel Performance on the left side go to how to's and FAQ's. there is a complete write up on it for the OBS. auto's or 5speeds. and back pressure won't just so long you aren't accelerating with it closed.
Old Sep 15, 2011 | 08:03 PM
joebob3093's Avatar
Moderator
it is not a "jake brake" it is an exhaust brake. i did it to mine and had it wired to a switch.
Old Sep 16, 2011 | 03:25 PM
85_305's Avatar
Being Evaluated
A jake brake is a brand of exhaust-brake... and no, you can accelerate w/ the ebpv engaged (because stock the programming allows you to accelerate up to 3/4 throttle I believe, w/out the ebpv disengaging). Wire it up to a switch somewhere.
Old Sep 16, 2011 | 04:08 PM
H.R.D's Avatar
A true Jake Brake is a engine compression brake. Not the same thing as an exhaust brake by any means. Yes Jacobs makes exhaust brakes but the are known for the Jake Brake.
Old Sep 16, 2011 | 06:04 PM
you cannot accelerate with it. when it is unmodified and is being controlled by the PCM, yes you can get to about 3/4 throttle then it will open. when it is on a switch, you override the PCM control. well you can still accelerate to a point but you have no power.
Old Sep 18, 2011 | 08:35 PM
Has anybody ever put a switch on their ebpv and melted wires? I used the 18 gauge wire that was said to be used in the write up on swamp diesel but it melted them and then I got 12 gauge and it worked but when I switched it back off and then on again, it melted the 12 gauge!
Please help
Nevemind. I got it Figured out
Last edited by Travistrent1993; Sep 18, 2011 at 08:35 PM. Reason: Automerged Doublepost
Pstroker73
Jul 9, 2015 07:55 PM
OBSBEN
Jan 8, 2015 08:21 AM
