big electrical issue
Old Sep 14, 2011 | 08:14 PM
wyodiesel92's Avatar
Default big electrical issue
Okay so i was driving out at the lakes and was going over a badly washed out road and i lost my radio, mirrors, interior lights, underhood light and i'm sure some other electrically controlled functions......i've gone through fuses, all are good with power flowing through and with as much as i'm dead set thinking it's a ground.
problem....haynes does not give hardly enough info on these systems to track down what's going on and where it is.....i started looking at all the grounds i could notice and they look good.
i found the ground on top of the drivers side fender, between the bed and cab, on the block and that's all i can really see on quick glance at this point.
my drivers side battery cable is just a little loose and won't tighten up any more.
I imagine there is a common ground for all of these fuctions and i can't figure out using my haynes book let alone where the grounds are located on the truck.
does anyone have any clues?
thanks in advanced.
Old Sep 14, 2011 | 09:05 PM
Whit's Avatar
Site Mascot
I too am thinking ground issues but cant really help ya other than look yer azz off and clean the crap outa things
Old Sep 14, 2011 | 09:09 PM
I might just have to buy alldata to be able to find everything
I want to try and avoid it though.
Last edited by wyodiesel92; Sep 14, 2011 at 09:09 PM. Reason: Automerged Doublepost
Old Sep 14, 2011 | 09:15 PM
aguilar_15's Avatar
Maybe some relay that interconnects all electrically controlled functions, can't think of one off the top of my head but I'm sure there's one somewhere. Good luck
Old Sep 14, 2011 | 10:20 PM
well if there was a relay for that wouldn't i loose all accessory functions? i still have power to my cell phone charger on the power outlet, cig lighter, the engine runs, headlights, taillights, and signals work.
not being rude just asking, my frustration about it kinda is making it hard to think
okay so update, none of the interior lighting works, including the glove box and my cargo lights do not come on either. cluster lights and other bulbs off the dimmer besides the cargo and dome light work
Last edited by wyodiesel92; Sep 14, 2011 at 10:20 PM. Reason: Automerged Doublepost
Old Sep 15, 2011 | 09:14 AM
greed's Avatar
I know you said you checked the fuses, but did you check the I.O.D. fuse (#12) in the dash? It will control all the items you mentioned.
Old Sep 16, 2011 | 12:36 AM
That fuse was still good. A buddy said today he had this problem and he just wanted his radio working and found that there was no juice and spiced in with a lead from the battery. He said after he did that everything magically worked. So I tried this with a power probe and sent power to the constant and got everything working. Now I have this temp fixed the way mentioned above but would like to actually fix it right. I haven't looked at any diagrams yet but I didn't know if maybe this would be a hint
This was on the constant lead to the deck sorry forgot that part
Last edited by wyodiesel92; Sep 16, 2011 at 12:36 AM. Reason: Automerged Doublepost
culp7
14
Jul 20, 2015 10:13 PM
CharlestonFF
Chevy/GMC Duramax 01-04 LB7
Jun 24, 2015 10:02 PM
Squirt
Jun 19, 2015 12:40 PM
RollinDiesel
Oct 14, 2014 03:13 PM
CARP
Oct 9, 2014 10:47 PM
