What do you guys think I should do?
Old Sep 13, 2011 | 12:15 PM
mcb's Avatar
mcb
Default What do you guys think I should do?
I have a 93 W250 5 speed. I want around 300 hp and I don't want to blow a @hit load of smoke. A little smoke is OK but no coal. I am going to go with a wastegated turbo for a couple of reasons but I don't know what size to choose. Compressor wheel size and exhaust housing size I am unsure of. And ofcourse what injectors to use that aren't smokey. Is the M&H timing spacer an advantage with what I am doing or is it only to help ignite huge injectors?
Right now I have a Denny T stage one, 3200 spring and the pump turned up just a bit.
Thanks for any advice.
Old Sep 13, 2011 | 09:06 PM
RSWORDS's Avatar
For that power goal I've been hearing alot of good things about the Variable vane turbos off teh new 6.7's. Some guys are running them on 1st gens with a homemade set up to activate the vains.
negadiesel
Sep 22, 2015 06:57 AM
ffmoofus
Jul 25, 2015 10:35 PM
Captainstubs1
Jun 16, 2015 03:50 PM
xj_crawler
12
Nov 20, 2014 10:17 PM
