white smoke
i get white smoke just after starting for a min. big deal? i have k&n airfilter,3'' down tube, 5'' exhaust, and a ts chip. and can u use califonia emissions injectors in a fed emissions truck? mine is a 97 7.3
What does the smoke smell like? Does it clear up pretty quick?
Yes you can swap in cali injectors but you will need to tuning to run them because they are split shot injectors vs a non cali truck which has single shot injectors...
ya goes a way in a min. i think its oil from the turbo. its only when i let it sit for a few days and thanks that what i thought about the injectors
Oil usually burns blue... White could either be unburnt fuel or coolant...
My guess is it's just unburnt fuel and as long as it goes away you should be fine. Does the truck struggle to start? Might be a few bad glow plugs...
mattshow123
14
Mar 12, 2018 01:41 PM
zoomer10h
Ford Powerstroke 08-10 6.4L
Feb 6, 2015 01:38 AM
