Edge COMP Power Numbers
Old Jan 4, 2008 | 07:32 PM
CumminsCrazed's Avatar
Default Edge COMP Power Numbers
ok guys, im just kinda curious if anyone knows how much power is added with the COMP in EZ mode (pump wire NOT tapped)
Also, if anyone has dyno results of their truck with COMP turned on and turned off to see how much power is created at the rear wheels compared to the advertised 120hp on the box. Would like this to be on otherwise stock truck except for intake and exhaust maybe. My mods are in sig.
anyone?
Last edited by CumminsCrazed; Jan 4, 2008 at 07:32 PM. Reason: Automerged Doublepost
Old Jan 4, 2008 | 10:52 PM
turbotrent's Avatar
Hey Zach, I think it's 75 or so. Tap the damn pump already!!!
Old Jan 11, 2008 | 07:58 PM
Rollin Smoke Diesel's Avatar
FormerVendor
Courtesy of Edge:
Power Level 1 on the Comp is the same as the EZ; on Power Levels 2-5 additional power is added via the wire tap onto the injection pump. If the pump wire is not attached with a Comp, Levels 2-5 are still operational, but the power gain is not any higher than Level 1. Under this scenario, however, power will come on much earlier in the throttle
So power level 1, the same as the EZ is 65hp and 185 ft lbs of torque. No dyno, but I can tell you its a big seat of the paints difference in between a Edge EZ and a Comp on 5x5.
Old Jan 13, 2008 | 03:48 PM
SuperDave4x4's Avatar
1st run Comp on 5x5
2nd run Comp on 5x5, but the TC was slipping at this point.
3rd run Comp on 4x5 I think.
I had a stock tranny with a shift kit, BHAF, and stacks.
Old Jan 14, 2008 | 08:29 PM
Also I forgot to add this dyno was BEFORE I had the Drag/Hot upgrade done.
Rusted Dragon
Feb 27, 2015 09:46 PM
scottxmorris
Feb 6, 2015 05:33 AM
FF131
Jan 21, 2015 11:37 AM
scottxmorris
Dec 31, 2014 03:20 PM
