turbo question
Old Aug 21, 2011 | 11:56 AM
dylan.b's Avatar
Default turbo question
what is the easiest way to take off the silencer ring on my stock turbo?
Old Aug 21, 2011 | 03:38 PM
cummin_un_glued's Avatar
FormerVendor
2 screwdrivers
Old Aug 21, 2011 | 09:15 PM
dylan.b's Avatar
but is there any clamps or anything holding it on
Old Aug 22, 2011 | 06:21 PM
FormerVendor
its just a large snap ring so use the first screwdriver to get the end of it lifted up then slide the second under the end and flip it out
Old Aug 23, 2011 | 05:06 PM
dylan.b's Avatar
ok thanks for the help
Old Aug 23, 2011 | 06:05 PM
FormerVendor
no problem
Old Aug 27, 2011 | 02:52 PM
dylan.b's Avatar
im still having problems with geting my silencer ring off, i cant get my screwdriver under the little clamp right in front of the ring so i cant it off....any sugestions??
Old Aug 27, 2011 | 03:56 PM
mysterync's Avatar
Default Re: turbo question
First of all, it really has more intended use than a silencing ring. It's actually there to reduce turbulence entering the compressor.
If your determined to take it out, hold one end of the snap ring solid and use a 90 deg. Pick to pop the other side up. It can be a pain. Make sure to vacuum up any small shavings created from the removal
Old Aug 28, 2011 | 03:04 PM
dylan.b's Avatar
ok well do you recomend even taking it off? will it affect my boost pressure? and how much louder would it make my truck?
Old Aug 28, 2011 | 07:05 PM
mysterync's Avatar
It won't effect power or boost enough to notice, will make the charger sound a touch louder even more so with a decent intake....
If I wanted my turbo louder I would install supporting mods and a bigger charger but that's me.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
torg73
May 11, 2015 03:08 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
