Zero fuel pressure
Old Aug 17, 2011 | 10:02 PM
ShortestBus's Avatar
Default Zero fuel pressure
New Problem. Diesels are so damn finicky. If things just are'nt so they don't go.
I'm very sure I have no fuel pressure because I had a tattle tail leaking fuel injector when it was running. Now it won't even start and my snitching fuel injector is not leaking anything.
Must be lift pump or injector pump. How can I test one agianst the other to isolate the problem? Also I checked the silonoids in the system and they seem to work fine.
Is the lift pump in the fuel tank? Should I hear it running when the ingition is on?
Need your help Please.
Before I go back to gassers..
Sb
Old Aug 17, 2011 | 10:34 PM
wildbill's Avatar
Remove the fuel filter, then kick the key on. If nothing, or hardly anything comes out, bad lift pump.
Old Aug 18, 2011 | 07:03 PM
DieselCrawler's Avatar
wrong mr bill. the pumps are mechanical off the pass side of the block. just like a gasser. remove the bleeder vavle from the filter head, and hook a hose up to it. now have someone crank it. if no fuel comes out, could be 2 things. bad lift pump or broken off pickup tube.
how much fuel is in your tank?
Old Aug 23, 2011 | 05:32 PM
Rogers21's Avatar
how much fuel pressure would a working fuel pump read at, i'm having a similar problem only getting 5 pounds of pressure when cranking and its bleeding off almost instantly,tried crimping the lines and it's still bleeding off somewhere
Old Aug 23, 2011 | 08:24 PM
fuel pressure running is only 7 psi MAX. any higher will throw off the pump timing internally.
Old Aug 26, 2011 | 10:43 AM
Rogers21's Avatar
so it sounds like then five would suffice. we actually figured finally that our pressure is good but the bleeding off is the real issue. replaced fuel lines, o-rings, basically ran out of ideas. the only other spot we could figure was the injectors themselves.
Old Aug 26, 2011 | 06:29 PM
how full is your fuel tank? dual tanks or not?
Dbleo351
Nov 20, 2016 09:34 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
cummins Pride
Oct 6, 2014 11:28 AM
