bag of parts problem
Old Aug 16, 2011 | 09:31 PM
Colonelkiller88's Avatar
Default bag of parts problem
just installed the industrial injection bag of parts on my cp3. install went smooth. took it for a test drive and felt a difference in power. i hit about 60 mph and the wait to start light came on and flashed/dinged for a little bit then went off. about five minutes later same thing the wait to start light came on and continued to flash. checked for codes and got p1223 which is pedal demand sensor b circuit high input. does anyone know how to fix this issue? i have not noticed any power problems but it is annoying to have the light flashing and the dinging.
Old Aug 16, 2011 | 10:30 PM
wildbill's Avatar
Not showing that code in my repair manual. Maybe a mistype?
Old Aug 16, 2011 | 10:36 PM
I found the code in a lost of cummins codes on a thread in this forum. The code list went up to 1900 something. My haynes manual didn't have it either.
Old Aug 16, 2011 | 11:10 PM
Red_Rattler's Avatar
High Tech Redneck
I knew this code looked familiar... Bud had it pop on his 06 when he had a cracked injector line on number six... Google it and it's related to fuel issues to a point. But the line fixed his yours is a different story
Old Aug 16, 2011 | 11:19 PM
High Tech Redneck
What programing are u running?
Old Aug 17, 2011 | 11:24 AM
I have a smarty set on five
Old Aug 18, 2011 | 01:12 PM
I put the old fca in and the code cleared. Im going to try and send the one from the bop back to industrial injection. Wish me luck.
Old Aug 18, 2011 | 02:07 PM
High Tech Redneck
They know they have issues so I don't think it will be an issue. Everything I've read has been related to a software glicth from an ECM update with either the smarty doing it or the fca from the BOP not playing nice. They will send you another just hope it works out for ya. This def seems like a 05-06 issue though
Old Oct 7, 2011 | 12:17 AM
colbyrc003's Avatar
Im having the same problem with my truck. Just installed my smarty jr. Now its throwing this code randomly. Where is that circuit located?
Old Oct 16, 2011 | 07:01 PM
dcpowell17's Avatar
You need to reset your PPS.
Turn the switch on
Slowly press fuel peddle all the way down.
Then slowly return peddle to rest.
Turn the switch off.
This reset your peddle position switch.
The PPS runs a 5 volt reference signal. If you screw around with the cp3 pump the reference point is disturbed giving a circuit high reading.
Last edited by dcpowell17; Oct 16, 2011 at 07:01 PM. Reason: Automerged Doublepost
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
carid
Towing and Hauling
Oct 27, 2014 10:46 AM
Sculpturesylvan
Oct 18, 2014 10:40 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
