7.3 running like crap
Old Aug 5, 2011 | 05:24 AM
Bad93Cummins's Avatar
Default 7.3 running like crap
We put in new idm and new injector harness both sides with new gaskets. Truck has codes 1293 &1294. Also high side bank 1 & 2. Come up on scanner. Truck hard start, rough/shakey idle and no power. What the heck is going on?
Thanks for your time and info
Old Aug 5, 2011 | 09:29 AM
CSIPSD's Avatar
Your truck?
Why did you change the IDM?
Check the main harness that goes over the drivers valve cover.
Old Aug 5, 2011 | 10:03 AM
Yes.
The idm that was in truck was the guy I bought truck from buddys idm that he uses at his shop to test other peoples trhcks for fualty idm, so no matter what I had to swap out idm.
Check it out? Its looks in good shape
Old Aug 5, 2011 | 12:32 PM
CSIPSD's Avatar
You could have swapped in a bad IDM. Throw the old one back in and see what happens.
Make sure that harness is completely plugged in and the bolt is tight.
Old Aug 5, 2011 | 12:47 PM
We did scanner first had 4 codes, swapped idm and took half codes away
Old Aug 5, 2011 | 12:59 PM
CSIPSD's Avatar
Lost...
it was running bad before you swapped IDM's?
Did you plug in all the injectors? Make sure none of them worked loose.
Old Aug 5, 2011 | 03:41 PM
Yes running bad before idm swap. I think it has a bad injector as it sounds like a miss.
Got 3 guys on another fourm that say all 3 of idms are bad, so going to head to slims diesel to try and get confirmation on problem
My buddy slim at Slims repair(diesel shop) got it for me. Trucks needs injector 3 & 8 replaced, doing that next week along with clutch pedal assembly and getting old freon/air outa lines and putting in new freon hopefully get ac going again.
Last edited by 95powersmoker; Aug 5, 2011 at 05:37 PM. Reason: Automerged Doublepost
Old Aug 7, 2011 | 08:55 AM
Cps was fine, deffenitly needs #3 & #8 injectors which will get replaced this week
Powerstroke36
Sep 29, 2015 07:16 PM
willis964x4
9
Aug 22, 2015 12:21 PM
Msc
Apr 23, 2015 06:21 PM
1997fordf350
Jan 15, 2015 06:12 PM
carid
Diesel Bombers Sponsors
Jan 12, 2015 04:32 AM
