fuel pump
Old Jul 31, 2011 | 09:50 PM
89_7.3idi's Avatar
Default fuel pump
Well after finding the first leak i have found another.the pump is leaking out the weep hole so im gunna replace it but was wondering if there was a tutorial with pics on how todo it.from what iv herd its gunna be a pain in the a$$
Old Aug 1, 2011 | 08:41 AM
PHPDiesel's Avatar
Sponsor
EASY.
Remove the fuel bowl at the same time...it makes the job a snap.
Really, there are only 4 bolts that need to be taken out plus the big banjo bolt at the rear of the pump. 1 1/4 wrench for that. Hope you have small hands......
The two bolts for the fuel bowl are 13mm. There is a harness connector there as well as the drain valve hose.
The two bolts for the pump are 10mm and there are three hoses....but you can replace those while you're in there so just cut them off. You will need three short sections of 3/8" hose and one short section of 5/16 hose (by short section, I'm talking about 2.5"-3").
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
bud0994
9
Jun 8, 2015 06:15 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Gm3500
May 7, 2015 11:01 AM
