thirsty diesel
Old Jul 30, 2011 | 05:18 PM
ted t's Avatar
Default thirsty diesel
lost fuel pressure. had plenty of fuel in tank. removed line from pump on rail it had no fuel in it dropped tank and cleaned mixer and tank. I also replaced fuel pump. I got plenty of pressure up to filter bowl but truck did not start. It will not hold pressure in line
Old Aug 1, 2011 | 07:28 AM
cummins_guy's Avatar
the bowl assy sometimes leaks, look in between the block below the cover, if you see diesel, you might have a bad one. plus under the hood it smells like diesel.
Old Aug 1, 2011 | 01:04 PM
ted t's Avatar
Ipulled the cap on the fuel filter and it was full of fuel.
Old Aug 1, 2011 | 02:37 PM
you can still have a full bowl, the assy can still leak.
right in between the two banks (where the engine makes a v) look down there to see if there is any fuel on the block, if you do, then your assy is leaking and has to be replaced.
not sure if this is your problem, but I have seen many 7.3l do this, and 90% of the time, that is the problem.
good luck
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
May 28, 2015 11:45 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
