gas pedal conversion for a cummins, an rad ?
Old Jul 30, 2011 | 11:38 AM
fbfootball's Avatar
Default gas pedal conversion for a cummins, an rad ?
i have a 01 chevy with a 8.1l an it has the electric throttle body with the electric gas pedal. my question is does a pedal from a 6.0 chevy with the cable throttle body, fit in the same place as the 8.1l pedal. also does any one know if the radiators are diff from the damx one an the 8.1l. if i dont have to change the rad. with it hold up with the cummins 12v. thanks
Old Aug 3, 2011 | 11:36 AM
Rayjon's Avatar
yes it will that is what I did in my 96 bolted right up and used the gm gas motor cable...
Old Aug 7, 2011 | 09:05 AM
fbfootball's Avatar
thanks and would u know if i could just rotate the oil pan around, so it could not hit the diff with no lift kit thanks
Old Aug 11, 2011 | 05:45 AM
andrewmp6's Avatar
If you make a oil pickup that could work if all the bolt holes are the same.
Old Aug 12, 2011 | 06:45 AM
fbfootball's Avatar
can anyone give me info on putting a 24v out of a 99 i can get the hole truck but i need to know how hard it would be to do the swap with the 24v thanks.
Old Aug 12, 2011 | 10:50 PM
andrewmp6's Avatar
Its the same but you got to swap the wiring harness and ecu.I would keep that as a back up a 12 valve is a lot simpler to do.
Daylon
Aug 23, 2015 11:01 AM
diggybiggs
May 14, 2015 11:51 PM
RedChevy44
Apr 21, 2015 05:47 AM
Chummins80
Feb 28, 2015 08:34 PM
mt grizzly
Dec 31, 2014 12:13 AM
