chevy gas swapped for a dmax
Old Jul 20, 2011 | 05:27 AM
fbfootball's Avatar
Default chevy gas swapped for a dmax
i have a 8.1l in a 2001 chevy 2500hd with an Allison an i was wondering what i would need to swap in a dmax.i know i will need the motor, an i think the tc for a diesel one. what else would i need to do. if its going to take a long time i might just try selling it an looking for a dmax, but i would like to know how hard it would be to do it thanks.
Old Jul 20, 2011 | 09:01 AM
Red_Rattler's Avatar
High Tech Redneck
Motor mounts, all the wiring and ECM and PCM, fuel lines and sender in the tank. You'd be miles ahead to sell yours and go from there.
Old Jul 20, 2011 | 10:06 AM
fbfootball's Avatar
i was told that the wiring harness in the 01 that i have is very similar to what the diesel one has an as for the fuel lines and sender unit would just a fast system work an just remove all the gas lines an have ones mad up to supply the engine.
bc why i want a diesel bc i just bought that 01 8.1 like a week ago an im looking at my gas bill an its horrible an i bought it bc i needed a truck when i get back from iraq an i was on rr so thats why i did that. if u know any one that would a truck like this for toeing or something like that hit me up it has 161,000 an its 4x4 excab i have it on craiglist in corpus christi texas.
Last edited by fbfootball; Jul 20, 2011 at 10:06 AM. Reason: Automerged Doublepost
Old Jul 20, 2011 | 12:55 PM
High Tech Redneck
for the wiring harness close doesnt cut it and you dont need a fass pump on a dmax since the cp3 pulld its own fuel but even if you put a fass on that system uses about 85% of the stock fuel system to work
Old Jul 20, 2011 | 01:23 PM
fbfootball's Avatar
so all i would need is the complete wiring harness for the motor only right an as for the fuel do i just need to replace the lines an the pump in the tank. then replace the ecm, an get it relearn an motor mounts. as for the mounts do i just need to get dmax ones or i need ones fab up.
Old Jul 20, 2011 | 04:41 PM
High Tech Redneck
should be the same cradle so the factory dmax ones can be used
also radiator, intercooler and all the piping and hoses for that
Old Jul 20, 2011 | 05:01 PM
fbfootball's Avatar
oh k thanks now i need to figure out what i need to do thanks
Old Jul 23, 2011 | 05:07 AM
fbfootball's Avatar
i was thinking what about a cummins 12v in the truck what would i have to do for the trans an other things. i know that the 12v does not have lots of electronics on it but as for the truck what would i need to do thanks.
or would it be alot simpler to put like a 24v or something with electronics thanks
Last edited by fbfootball; Jul 23, 2011 at 05:07 AM. Reason: Automerged Doublepost
Old Jul 23, 2011 | 10:07 AM
turbostang7's Avatar
it would be simplest to do a 12 valve swap, but you will have to buy an adapter to go to the allison with a standalone controller iirc fleece makes one. and its not cheap. i would say the cummins swap would come in around $5k or you could just watch the internet and find a wrecked dmax for around there and have everything for that swap. honestly i would save the money, sell your truck and just get one, much easier and no little surprises that all swaps have.
Old Jul 23, 2011 | 11:21 AM
fbfootball's Avatar
why would the allison need a standalone controller an are they like the ones destroke sales.
an if i stay with the dmax i was told that my transmission would not bolt up to it bc it has a gm bell housing from the 8.1l an the dmax is some other kind of housing.
