E99 F350 4x4 cclb 6spd
Old Jul 12, 2011 | 03:01 PM
Bad93Cummins's Avatar
Default E99 F350 4x4 cclb 6spd
Looking at getting this truck. Body is perfect/no rust, brand new 35s, 16"(look like alcoas), randhand front, interior very nice. Had injector cups and o-rings replaced as some where cracked. Guy said had bad #4 injector so replaced with brand nee, so truck runs better/less smoke but still has to pull pass. Cover as he says still weak injector/miss. Truck has 291,000 miles but looks taken care of. Whats your opion? Also what is usual cost for motor rebuild and time consumption?
Thank!
Very excited, kinda my dream truck so very instrested in truck
Also, when bought my first powerstroke(94.5) it had bad injector so kinda have idea of no real power and will look at replacing all injectors with stage 2s asap as money allows.
Is there a way to check codes without programmer/computer? I know on my old 02 cummins you cycled the key 3 times and it would read codes out in odometer.
Old Jul 12, 2011 | 03:35 PM
gradyc's Avatar
You have to have a scanner for the powerstrokes. The cheep scanners from the auto parts will not work either. it is either a more expensive scanner designed for the diesels or the auto ingenuity that works with a laptop.
Old Jul 12, 2011 | 06:09 PM
95powersmoker's Avatar
Sounds like a high mileage truck... Hopefully the price reflects that. Take a look at everything.
Old Jul 12, 2011 | 07:07 PM
Ya its high mileage, but deffenitly looks brand new, looks well taken care of, hopefully check it out this week
Old Jul 12, 2011 | 08:32 PM
CSIPSD's Avatar
Keep in mind the E99's were the bastard child... Different hubs, front end components, turbo set up, smaller HPOP, PCM...
With almost 300k, if the price is not cheap, I would not touch it.
Old Jul 12, 2011 | 08:50 PM
What you mean by odd componets? I thought e99s whete pretty much obs setup but with intercooler? And its 350 so has d60 front
Old Jul 12, 2011 | 09:16 PM
CSIPSD's Avatar
https://www.dieselbombers.com/ford-p...tml#post666694
Check out the stickys at the top of this forum, lots of good info in there.
Old Jul 13, 2011 | 06:38 AM
Sweet thanks for link
Old Jul 14, 2011 | 06:34 PM
Guy say's truck runs pretty decent, when he got it it needed injector cups, so he did those, then sucked all fuel out and did fuel filter and all new good diesel fuel. replaced one bad injector on driver side, still have to do pass. side. He says a slight haze of blue smoke when idiling but goes away. maybe need turbo rebuilt?
Going to try and go check it out saturday.
Last edited by 95powersmoker; Jul 15, 2011 at 05:31 PM. Reason: Automerged Doublepost
smbenoit_79
May 19, 2015 01:32 PM
zoomer10h
Ford Powerstroke 08-10 6.4L
Feb 6, 2015 01:38 AM
2FordStrokers
Jan 11, 2015 09:40 PM
fatography
Oct 23, 2014 08:23 PM
