riffraff over boost code regulator codes HELP!!!
Old Jul 8, 2011 | 07:04 PM
shorty2tall's Avatar
Default riffraff over boost code regulator codes HELP!!!
after i put on the riffraff over boost code regulator on im getting 1247 1248 no or little boost should i take it off till i get the up pipes installed and ill be making more boost?
it adjustable so it isnt showing any boost?
Old Jul 11, 2011 | 03:30 PM
CSIPSD's Avatar
Do not adjust it. It should come preset. Just because you installed it does not mean you will make more boost. I would check to make sure your MAP sensor is reading anything at all.
Sounds like the wiring got bumped or removed on the install.
Old Jul 12, 2011 | 12:05 AM
k ya its fine if im in the extreme tune in tow it shows no boost will the up pipes help?
dwmeehan
Sep 6, 2015 04:20 PM
flash7210
Jul 5, 2015 09:25 AM
Un4givn
10
Apr 27, 2015 01:58 AM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
