OM617 advancing injection pump question
Old Jul 8, 2011 | 12:24 AM
Jordank520's Avatar
Default OM617 advancing injection pump question
What is the easiest way of going about adjusting the injection timing? I know you have to loosen the 3 bolts and then tilt the injection pump towards the drivers side. but there has to be more to it i just don't know what. any help will be appreciated
Old Jul 8, 2011 | 01:00 AM
mr_manny's Avatar
free service manual download, for your viewing pleasure
Auto service & repair manuals: Mercedes-Benz 200D, 240D, 240TD, 300D, 300TD Owners Workshop Manual
Old Jul 8, 2011 | 12:23 PM
FTE's Avatar
FTE
Tilting it towards the drivers side will retard the timing. I used the drip method, cutting up an extra line and bending it to the shape required. Follow the instructions in the manual. I am currently running 27 btdc. It has way more low end, but sounds more like a cummins at idle.
Old Jul 8, 2011 | 09:00 PM
Jordank520's Avatar
perfect, thank you
Old Jul 11, 2011 | 09:45 PM
dsltoy's Avatar
Originally Posted by mr_manny
You are amazing I have been searching for a free manual for a while. Thanks.
Old Jul 12, 2011 | 06:49 PM
redneckvette's Avatar
first i marked the pump and block to show were it was before then losened the three flange bolts and the back bolt by the filter housing and turned the pump twards the motor. the mark on the block and pump are only about a 16th of an inch difrence but it is faster now. the down side is i think my fuel milage is suffering from it. not to sure since my speedo doesnt work.
Old Jun 7, 2012 | 11:26 AM
mystryda's Avatar
Default Repost the manual, please?
Would somebody who has the manual please post it, again? I just found this thread (and need the manual), but the link to the manual is old.
(Yes, old thread, but resurrecting it seemed like the best course of action.)
PA 24valve
Aug 31, 2015 06:08 AM
Forks diesel nut
Jul 27, 2015 12:19 PM
moneypitk5
Feb 12, 2015 11:01 AM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
