Is this a transmission problem?
Old Jun 27, 2011 | 12:13 PM
keferson's Avatar
Default Is this a transmission problem?
I'm new to posting and new to my 2000 ford excursion diesel. I had a 2000 V10 Excursion and traded for a diesel. I've been having it worked on and trying to get it to run like it should, based on my research of mpg, turbo, towing, etc... Thought it was doing OK. Then this week, a friend is driving it and it loses all gears instantly. Now it's sitting in my driveway motionless. There's no reverse and there was no slipping to indicate transmission problems leading up to it. When we went to check the transmission fluid after towing it home, the dip stick tube had broken off. But, we didn't see any fluid on the engine or ground. Also, the gear shift moves through the gears but doesn't engage at all. I'm a little puzzled that it happened so fast. Any ideas, or places to start looking, I'd appreciate it.
Old Jun 27, 2011 | 01:08 PM
CSIPSD's Avatar
Does the park pos still keep the truck from moving?
Sounds like you broke the foward drum or center support. Hate to tell you, but the tranny is toast
Old Jun 29, 2011 | 06:20 PM
95powersmoker's Avatar
What ^^^ said... Time for a rebuild...
Old Nov 7, 2011 | 12:44 PM
XKurSion's Avatar
Default Excursion
I have this exact same problem with mine, heading out for a trip to northern, ca. Then the transmission just died. Have you fixed yours? Could you tell me what the problem is?
Thanks
Old Nov 10, 2011 | 12:36 PM
XKurSion's Avatar
bump
Old Nov 10, 2011 | 12:59 PM
The hosser's Avatar
something like this happened to my truck. nothing would engage and it happened all the sudden. well something fell out and hit my foot. i dident think anything of it till i got back in my truck and noticed the problem. dang it my tranny just went i though. well i took a closer look and noticed that what hit my foot was a bolt that holds the gear shifter lever to the whosssie whatsit whitchama call it. put it back in all was good.
Old Nov 11, 2011 | 06:07 PM
bowietrucking's Avatar
yeah, what he said! mine got really loose too but didn't actually fall out and i thought it was the shifter cable itself. ordered a new cable and seen the dang bolt was falling out! its a star bit, i'd put a dab of blue loctite on that sucker!
Old Nov 12, 2011 | 12:24 AM
XKurSion's Avatar
Default Thanks
I am keeping my fingers crossed that this is the issue. I'm going to go check it out tomorrow.
Thanks
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
TheDirtyDozen
Oct 1, 2014 10:09 AM
