99Cummins 24v repower into 96 GMC CC-DRW-SAS
Old Jun 21, 2011 | 03:38 PM
Dru's Avatar
Dru
Default 99Cummins 24v repower into 96 GMC CC-DRW-SAS
So the repower is under way. Bought a rolled 99 24V 4wd Dodge with a good amount of aftermarket stuff for the right price, hence a 24v auto swap (I know a P pumped 12v with a 5 speed would have been great) Anyway here is what we have so far.
The GMC began life as a 6.5/Auto 4x4 Blue stock truck.
Somewhere along the line a big block found its way under the hood, the wiring is pretty hacked up right now, but it will be done right.
Looking for the most in-depth wiring schematics on both vehicles.
As for the Alternator I am using a 5.9 24v alt that came off a freightliner for providing signal to the tach
Mounts, Quad autoworld setup
Custom Crossmember
Possibly using the dodge AC compressor
As for the aftermarket goodies, there are plenty
Any advice, words of wisdom, or anything else anybody can send my way are much appreciated
Old Jun 23, 2011 | 08:40 AM
Dru's Avatar
Dru
Old Jun 23, 2011 | 02:39 PM
motochump's Avatar
Awesome!!! I will be following this one. I am about to put my 12 valve into my 98 chevy crew cab. keep coming with the pictures.
Old Jun 23, 2011 | 07:22 PM
chevyhoss's Avatar
cool swap keep the pics comin
Old Jun 27, 2011 | 01:38 PM
Dru's Avatar
Dru
Got the motor in, and have contacted dakota digital about making the chevy speedo work with the built 47RE from the dodge, just need to find out the pulse count output sent from the dodge unit to see if the Dakota Digital Universal Speedometer Signal Interface will work for my swap, anybody know anything about pulse count (speed sensor output) on a 47RE?
Old Jul 6, 2011 | 08:00 PM
Dru's Avatar
Dru
Anybody????
Old Jul 15, 2011 | 06:18 PM
Dru's Avatar
Dru
Delco Remy 150 amp alt is in
Frame is notched
dodge ac comperssor being used
core support work done
Old Jul 15, 2011 | 06:56 PM
cummin_un_glued's Avatar
FormerVendor
call destroked they can tell you the count
Old Jul 20, 2011 | 05:47 PM
Dru's Avatar
Dru
One off mutant drive shafts are being made now to match the dodge powertrain and Ford axles, definately some Frankensteins
Old Jul 22, 2011 | 05:07 PM
Dru's Avatar
Dru
Driveshafts done!!!
