need more HP
Old Jun 21, 2011 | 12:05 PM
jwyeater's Avatar
Default need more HP
I do alot of pulling and was wanting to know how to get more HP out of this 6.5. I have a 93 gmc 3500 converted to flat bed,single axle 4 x 4, 5 speed. Seem to lose power on hills. Any suggestions?
Old Jun 21, 2011 | 02:55 PM
6.chevysuburban's Avatar
Turn the pump up, put marine injectors in it. If you do that I would suggest putting water injection on it. Then put an exhaust temp gauge on it... That's a must!
Old Jun 21, 2011 | 08:51 PM
Woody35's Avatar
marine injectors wont do much but turn the fuel screw but you need to up the boost a little bit and make your getting fuel to the ip
Old Jun 21, 2011 | 10:24 PM
Crazy's Avatar
X2
Old Jun 23, 2011 | 04:11 PM
jwyeater's Avatar
I have heard about turning pump up, but not sure how to do it. Also, was told , I would need to get more air into it. Then would need bigger exhaust. What is water injection?
Old Jun 24, 2011 | 02:00 PM
wpg6.5's Avatar
exhaust is a must, water meth works well too ive heard. turning the pump isnt too bad a few guys on here have detailed instructions on how to do it. and making an intake isnt too hard, a 3 inch 180 degree bend exhaust pipe will work, making one now. pulling the vacuum pump and making a manual boost controller helps, and a heath or walking j tune will really wake her up. i can walk 350 gas trucks all day. and i have 4 by
Old Jun 27, 2011 | 09:41 PM
palmer6.5td's Avatar
Could a person get their stock injectors remanned to 2100 psi?
Old Jun 28, 2011 | 12:20 AM
Woody35's Avatar
yeah it takes a few shims. got to get them pop tested though to make sure the nozzles are good first
