upper radiator hose
Old Jun 16, 2011 | 04:46 PM
BVFD54's Avatar
Default upper radiator hose
Anyone had the problem of the upper radiator hose sucking itself flat??? It has a new one on it and it will suck it flat and heat up quick.... 1994 F-250 7.3L stock turbo
Old Jun 16, 2011 | 06:44 PM
DieselCrawler's Avatar
check your rad cap.
Old Jun 18, 2011 | 11:05 AM
BVFD54's Avatar
has a new one on it and i pressure checked it and the radiator.
Old Jun 18, 2011 | 03:05 PM
possible it is the wrong cap? for some reason your system is holding vacuume
Old Jun 20, 2011 | 05:48 PM
BVFD54's Avatar
could the thermostat be causing it by any chance?
Old Jun 20, 2011 | 07:26 PM
possibly, but doubt it. could be the bypass in the thermostat housing is blocked. if u do swap the tstat, only install a ford or IH one.
Old Jun 20, 2011 | 09:56 PM
css89's Avatar
Default overheating
did you change thermostat when you put new hose on? and if you did possibly you put thermostat in backwards.
Old Jun 26, 2011 | 08:13 PM
BVFD54's Avatar
no didnt change tstat but i am in the process now and the bypass was blocked by the way......
Old Jul 4, 2011 | 11:15 AM
BVFD54's Avatar
It ended up being the thermostat. Thanks for the input
Walker.B
Chevy/GMC Duramax 01-04 LB7
11
Jun 17, 2015 10:40 PM
oznation
May 26, 2015 09:23 AM
jrsavoie
Feb 6, 2015 09:44 PM
