6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Oversize turbo??
Old May 29, 2011 | 12:28 PM
FRIDAY88's Avatar
Default Oversize turbo??
Is anyone running the hybrid turbo without studs is it head bolt safe I dont think the hybrid is a whole lot bigger more CFM but not much more boost would I be safe?
Old May 30, 2011 | 11:47 AM
Mdub707's Avatar
What is it you're trying to do? Slapping a larger turbo on doesn't mean you're going to get more power right away, in fact it may be worse. Just because a turbo is larger, doesn't mean it's going to perform better.
What do you use the truck for, and what are your goals for power and such? Are you running stock injectors? Are you planning on upgrading injectors at any point? Just running hot tunes now? Need more info here.
The powermax is a GREAT upgrade over stock for those running stock or slightly larger injectors. Spools like stock, and will support a little more power over the stock turbo.
Old May 30, 2011 | 05:05 PM
FRIDAY88's Avatar
Well this one says great for a little over stock quicker spool up lower egts and moves more air but no more boost just more cfm I have stock injectors
Old May 30, 2011 | 05:12 PM
HeavyAssault's Avatar
What is the exact turbo you are talking about? I have the PowerMax with the original head bolts....no issues.
Old May 31, 2011 | 07:28 AM
Mdub707's Avatar
You didn't answer any of these questions, and you really can't pick a turbo out until you do.
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
