Turbo exhaust leak
Old May 28, 2011 | 12:40 PM
redneckpipeliner's Avatar
Default Turbo exhaust leak
I have a 2000 F-350 7.3 and I have an exhaust leak on the turbo, between the cold air side impeller and the hot exhaust side, the problem is that as you may have noticed, I dont know the correct terms for the turbo parts so I dont know what parts to get to fix it. Any help would be appreciated.
Knowone has any advise on this?
Last edited by redneckpipeliner; May 28, 2011 at 12:40 PM. Reason: Automerged Doublepost
Old May 28, 2011 | 12:54 PM
ZombieSoldier's Avatar
is it on the spider?
Old May 28, 2011 | 01:56 PM
Will have to google turbo spider, dont know what a spider is.
Looks like mine is leaking between the mounting bracket/spacer that bolts the turbo to the pedestal that is between the cold side and the hot, the actual leak is between the mounting bracket/spacer and the hot side. If you go to my album I uploaded a pic of someone elses , doesnt have a leak but between the rusty spacer and the shinny exhaust side is where mine is leaking.Does that help any?
Last edited by redneckpipeliner; May 28, 2011 at 02:01 PM. Reason: Automerged Doublepost
Old May 28, 2011 | 09:56 PM
gradyc's Avatar
If I understand your description of the picture correctly the leak is between the turbo exhaust housing and the main turbo bearing housing. I haven't had one of these turbos apart yet but someone out there probably has and can tell you if there is a gasket or how it is sealed. The exhaust housing will have to be removed to fix it.
Old May 28, 2011 | 10:40 PM
Turbo exhaust housing, that sounds right, and where is the main turbo bearing housing, is it where the 2 long bolts are to bolt the whole thing to the pedestal, right in the middle between the 2 impellers?
Old May 29, 2011 | 01:11 PM
gradyc's Avatar
Yes. that is the maim housing. It is the rusty part in the photo.
Old May 29, 2011 | 01:15 PM
Ok, great, thanks, now that I have a few names I was able to find out that there is no seal there, just clean metal to metal, now just to figure out why it is leaking and how to fix it.
avatardvr
18
Aug 8, 2019 12:38 AM
makuloco2000
Dec 20, 2015 11:19 PM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
D-350 dually
Apr 11, 2015 11:38 PM
