high trans temp??
Old May 25, 2011 | 09:38 PM
99stackedpowerstroke's Avatar
Question high trans temp??
okay so heres the deal i had my trans rebuilt, it usually runs around 130 highway and 1six0 in town, i hooked up to the trailer and loaded my ranger put my chip on 80hp tow setting and took it 10 miles and off loaded temp got to about 190, and thats going up a pretty big hill, then i loaded a 78 reg cab short bed chevy with 8inch lift stock tires and hauled it about 10 miles, my temp went to 210!!! on highway got to about 70 max in town was 30ish with o/d off, is this average or high?? oh and outside temp was around 70 while doing this
Old May 26, 2011 | 09:10 AM
CSIPSD's Avatar
190 I would not be concerned with, but the 210 is getting hot for just a light load. Do you have an added cooler?
Old May 26, 2011 | 02:01 PM
PHPDiesel's Avatar
Sponsor
Personally, I wouldn't worry until I hit about 240 degrees sustained. 210 really isn't that hot.
If you're getting that warm while driving down the highway with the torque converter clutch applied, it's time to look into a larger cooler. If it's that hot around town, then the torque converter clutch isn't applied and there's your reason for the higher temperatures. With stock or our standard tunes, there's no way to have a TCC apply at 30 MPH, so your transmission is going to run hotter.
Old May 26, 2011 | 04:57 PM
yes i am running a hayden 1401 is that one big enough or do i need a bigger one? and i do have it located in front of the A/C so its the first thing the air hits
Old May 27, 2011 | 08:33 AM
PHPDiesel's Avatar
Sponsor
Run it.
Worry if it hits 240.
Old May 27, 2011 | 05:32 PM
okay just kinda worried me, i mean it is an awful light load isn't it??
john grossman
10
Jan 12, 2019 08:58 PM
Jake9473
Jul 22, 2018 08:19 AM
ctd04x4
Sep 11, 2015 03:50 AM
casper83
23
Jul 27, 2015 01:53 PM
robbyS
Apr 16, 2015 02:22 PM
