Rough idle
Old May 24, 2011 | 05:34 PM
Travistrent1993's Avatar
Default Rough idle
My truck has a rough idle for a few seconds when I first start and sometimes when I push the clutch in to stop. Just anybody know what causes this? Is it a bad thing?
Also sometimes when I go to start it, I will think it is goin and when I let off it just dies. Then I start it up again and it has a little white smoke come out? I'm just trying to figure out if something is about to go out or if that is normal? My buddies has a rough start too.
Old May 24, 2011 | 06:32 PM
95powersmoker's Avatar
How many miles on the truck?
Next time before you start it, Check your HPOP reservoir level...
Old May 24, 2011 | 09:46 PM
Only 98k. It only does it sometimes. Like earlier I was messin with my exhaust and started it up and it was perfect and revved it up and it did perfect. It only does it sometimes. But when I put it in neutral and roll up to a traffic light, I can feel it idling rough and the gauge jerks a little
Old May 24, 2011 | 10:48 PM
Twebb833's Avatar
I had a similar problem. It was the dual mass flywheel.
Old May 24, 2011 | 11:25 PM
I just had a new clutch put in at the dealership? Prolly about 2-3 months ago
Also do our trucks have intercoolers or is that the trans cooler in the front at the bottom or what is that?
Also my buddy has a 97' that has an automatic trans and his does the same thing starting up?
Last edited by Travistrent1993; May 24, 2011 at 11:25 PM. Reason: Automerged Doublepost
Old May 24, 2011 | 11:27 PM
No intercooler on OBS trucks...
Mine used to lope when I first started the truck, Doesn't do it now that I swapped injectors.. That shouldn't be your problem though.
Old May 24, 2011 | 11:40 PM
So what is the little radiator thing right behind the bumper?
Old Jun 15, 2011 | 08:08 PM
bowietrucking's Avatar
hey, i've noticed my truck will stumble and lope if i'm pulling up to a redlight and kick it in neutral to coast to the light at say 5mph or so. i dont think its in the clutch, but it could be? my trucks a 95 dually, manual.
Old Jun 26, 2011 | 12:16 PM
Twebb833's Avatar
You didnt happen to replace the dual mass when you did your clutch did you?
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
Jan 21, 2015 10:47 AM
Snoobly
Dec 11, 2014 11:59 AM
cdetterer
15
Dec 8, 2014 08:46 PM
99stackedpowerstroke
Oct 8, 2014 07:06 PM
