i gotta tough one this time 01 7.3
Old May 17, 2011 | 06:58 PM
wisakowsky's Avatar
Default i gotta tough one this time 01 7.3
Started my truck this morning and it had a extremly rough start with white and a lil blue smoke. I know white is water and blue is oil. It sounded like there was something loose in the motor. So i decided to drive it anyways and the smoke went away and the noise withen 2 miles of my house. Still has not came back, also i found a little piece of what lookes to be two pieces of copper pressed together in my exhaust, could it be exhaust donuts, if it were a head gasket i would think i would still be smoking with contaminated coolant/oil. My turbo seems to work and boost normaly sometimes but other times seems like there is no boost what so ever. and EGTs seem a little higher which would make sence if my turbo was not working properly
any help is appreciated mechanical problems useually do not fix them selfs and i am stumed.
Old May 17, 2011 | 07:09 PM
Lange503's Avatar
sounds like the up-pipe gasket if i'm not mistaken?
Old May 17, 2011 | 07:12 PM
Mr. Miyagi's Avatar
White is also raw, unburned fuel....which is what happens when a diesel cranks/no starts while fueling. Don't light a match.
Old May 17, 2011 | 07:35 PM
wisakowsky's Avatar
that is what i am thinks as well is there a upgrade for the up pipe
would the leak in a uppipe cause low boost high egt ect.
Last edited by wisakowsky; May 17, 2011 at 07:35 PM. Reason: Automerged Doublepost
Old May 17, 2011 | 09:25 PM
cdiesel's Avatar
yea, my up pipes were leaking and couldn't get good boost and the egt's were climbing slowly. Fixed them and its all good now.
Old May 17, 2011 | 10:34 PM
95powersmoker's Avatar
Yes Sir.
Old May 17, 2011 | 11:16 PM
wisakowsky's Avatar
thank yall so much i am going to put the international up pipes on and see where that takes me
Browe347
Dec 11, 2016 02:59 PM
E350Hawaii
May 20, 2015 12:46 AM
Mar 19, 2015 08:10 AM
UniqueCopy
Dec 14, 2014 11:37 AM
Browe347
Sep 30, 2014 11:35 PM
