won't start
Old May 11, 2011 | 05:43 AM
smokeybee2's Avatar
mad won't start
truck died replaced CPS and it will only start and run as long as either is kept spraying into ait intake.Is it possible oilpump is shot? Fuel pump appears to be working.
Old May 11, 2011 | 10:11 AM
95powersmoker's Avatar
First off, quit using Ether. You should never use ether on a motor that has glow plugs... Bad chit happens...
We're going to need some more info to help you out... Any sputtering when it died, miles, When cranking, is the tach moving? Smoke out the tailpipe when cranking? Does the WTS light come on when you go to start it?
Welcome to Diesel Bombers by the way.
Old May 11, 2011 | 01:50 PM
CSIPSD's Avatar
Welcome to the site!!! James asked the right questions...
Old May 11, 2011 | 04:01 PM
smokeybee2's Avatar
Default smokeybee2
I think we found the problem. It appears to be the "injector driver module", at least that is what the scanner said. And no the tach isn't moving.No smoke.It just quit driving down the road no sputtering that I noticed. The light wasn't coming on,but we found a blown fuse and it comes on now.
We found a place in FL called COMPUTER EXCHANGE in DAVIE FL. WITH REAL GOOD PRICES. $139 FOR INJECTOR DRIVER MODULE . If this is what it turns out to be.
Old May 11, 2011 | 04:44 PM
CSIPSD's Avatar
I would do some more checking, I doubt its your IDM. If you blew a fuse I would check the fuel bowl heater and unplug it, then replace the fuse again because more then likely its blown now as well.
IDM's are pretty rare to go out.
Old May 11, 2011 | 05:24 PM
I agree, Not so sure it's the IDM. What code did you get that made you think that?
Old May 11, 2011 | 08:21 PM
cummin_un_glued's Avatar
FormerVendor
like they said try the fuel heater the fuse that feeds it also feeds the pcm and we have replaced a few heaters for the same problem your talking about
Old May 12, 2011 | 04:49 AM
smokeybee2's Avatar
P1298 code
Old May 12, 2011 | 10:48 AM
CSIPSD's Avatar
Well... 1298 is a IDM Failure code so...LOL
Sounds like you need an IDM.
Old May 13, 2011 | 09:30 PM
Any updates on this?
