dana 61 noises
Old May 5, 2011 | 10:19 AM
scottknight7's Avatar
Default dana 61 noises
I have an 84 6.9 4x2 with a dana 61 read end. When I shift I get a thunk like a bad u-joint, but all the u-joints are very solid with zero play. Also, under load (primarily in 1st and 2nd) I get a clicking noise. I laid under the truck with a friend rocking 1st to reverse and the thunk appears to be in the diff. The yoke has nominal rotational play and no in/out or up/down play and the diff has oil. Any idea's?? Daily driver that tows a 3k lbs trailer.
Old May 5, 2011 | 01:32 PM
DieselCrawler's Avatar
could be play in the spider gears or the cross pin. pop the cover off and take a peek.
Old May 5, 2011 | 10:09 PM
I got under it to check the yoke nut and the rear u-joint was stiff and chunky. It wasn't lube-able so I replaced it and everything seems OK. The bearings were really dry, and it had no zerk. I like the $15 fixes.
Thanks for the input.
woodsman27
May 23, 2015 10:16 AM
tractormandan
Wanted To Buy (WTB) - Used
May 9, 2015 08:44 AM
scrnnmssuck
For Sale
Mar 20, 2015 11:55 AM
KYLEBOY
Jan 18, 2015 06:36 PM
gyayo2012
Nov 15, 2014 08:11 PM
