Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
fuel additives
Old May 2, 2011 | 12:30 PM
Chad96Dodge's Avatar
Default fuel additives
I seen some stuff about it but nothing defining use. What does uesing 2 stroke oil in diesel fuel do? I just put this in my 12v cummins seems to show a difference. Diesel KleenŽ +Cetane Boost. Just seeing if someone could inform me on the 2 stroke oil thing. Thanks.
Old May 2, 2011 | 04:37 PM
gunman41mag's Avatar
Moderator
It lubricates
Old May 2, 2011 | 07:45 PM
Boiler01's Avatar
Ditto, no sulfur less lube and lube is good
Old May 2, 2011 | 08:13 PM
Moderator
But I won't add 2-stroke oil to my 6.4 POWERSTROKE only on the pre DPF trucks
Old May 3, 2011 | 09:29 AM
Whats DPF stand for?
Old May 3, 2011 | 09:37 AM
RAW's Avatar
RAW
Diesel Particulate Filter, it catches soot to be later burned out. It's an emissions control.
Old May 3, 2011 | 06:11 PM
oldsinner111's Avatar
Can these be removed?
Old May 3, 2011 | 07:09 PM
Moderator
Yes but you need a dpf/delete tuner
Old May 4, 2011 | 12:34 PM
So would my 96 have a DPF? and would I be safe to add 2 stoke oil? and if so how much 2 stroke oil do I add?
Old May 4, 2011 | 02:09 PM
Moderator
Truck didn't get DPF till 2007, so you're ok to add 2 stroke oil
