cummins swap trann questions
Old Apr 24, 2011 | 10:48 PM
JMort's Avatar
Default cummins swap trann questions
im getting ready to swap my 95 cummins in to my old ford, i missing a few parts i need info on. does any one know radiator hose numbers??? its got the 84 idi radiator and the cummins water neck that points strait up in the air..... next, the nv4500 clutch slave clinder to the ford master... how? or has any one here put a 4500 in an 80's ford? thanks in advance! Justin
Old Apr 25, 2011 | 09:34 AM
93_Fummins's Avatar
I just used a piece of universal flex-hose radiator hose for the top, you can get them in different lengths at the parts store and it worked fine for the top hose on my Cummins to IDI radiator. The bottom hose required a special crossover to run from the passenger side of the Cummins block to the drivers side of the bottom of the IDI radiator. I made the crossover out of mild steel pipe and used a universal 90* hose at each end connecting to the engine and radiator. Be sure to put a bead on the crossover if you go that route or you might blow the crossover off in the driveway!
As for the clutch hydraulics, if I recall correctly, you can drive the roll pin out of the master cylinder and mate the hydraulic line from the Dodge assembly to the Ford master cylinder.....that's what I did on mine, but it was with a Getrag clutch assembly, so I'm not certain on the NV4500....
Old Apr 25, 2011 | 06:18 PM
EasternAggie's Avatar
Not much help on the master/slave cylinder, I used the Dodge clutch master cylinder on mine, but there is a way you can hook them up.
Old Apr 25, 2011 | 09:12 PM
JMort's Avatar
i didnt think the dodge master would work on the ford...... or maybe i was just looking for the easy way out
DieselDan370
Aug 23, 2016 02:24 PM
STDiesel59
Jul 11, 2015 10:09 AM
jeremiah1
Jun 18, 2015 05:01 PM
mdub4life29
May 9, 2015 10:04 AM
mcclusk
Feb 21, 2015 09:50 PM
