NV4500 to ford transfer case?
Old Apr 24, 2011 | 05:07 PM
black95cobra's Avatar
Default NV4500 to ford transfer case?
Curious, the transfer case is off of a V10 ZF6. NV4500 came out of a 96 ram 2 wheel drive. What does it take to make it work?
Old Apr 25, 2011 | 09:28 AM
93_Fummins's Avatar
Sounds like you need to convert the NV4500 to 4wd with a tailshaft housing and an output shaft, then likely a spud shaft conversion to change from the NV4500 tailshaft splincount (29 spline?) to the Ford spline count (32 spline?). Advance Adapters makes a kit for NV4500 to Ford transfer case, but IIRC you have to trim the output shaft of the NV4500 to clear the internal offset of the transfercase input...
Old Apr 25, 2011 | 11:34 AM
Thanks, I'll give advance adapters a call this week.
Old May 16, 2011 | 06:42 PM
Decided to stick with the ZF6, thanks
Jrod89
Feb 24, 2015 09:48 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
steves2500diesel
Oct 14, 2014 05:36 PM
