South bend clutch
Old Apr 19, 2011 | 08:09 PM
rocko cummins's Avatar
Default South bend clutch
I just ordered the dd3600 with the bigger input shaft I was wondering how hard is it to change the input shaft. Also is it better to go ahead and do the upgraded hydraulics. Thanks for the help
Old Apr 27, 2011 | 10:29 AM
2001 blue cummins's Avatar
The input shaft is easy to change, i think theres 4 bolts that hold it then seperate the cover with a flat head then the shaft pulls out. but as far as hydros goes, you wont need the upgraded ones.
Old Apr 27, 2011 | 10:32 AM
D-LUX's Avatar
i would depending on the amount of miles on your stockers...either way you'll find out when you do the swap and it will either disengage the clutch or not
Old Apr 27, 2011 | 11:27 AM
rednekroper05's Avatar
i would do the hydralic upgrade as soon as possible. i didnt when i went to a dd but i should have just didnt have the money at the time.
The input swap is super easy. Its only 4 bolts on the front and pull the plate. Somewhere i have the instructions saved ill try to find them. just be carefull when you are pressing bearings on and grease them up good. there is nothing like chasing rollers around several times
Old Apr 27, 2011 | 01:15 PM
Default Re: South bend clutch
I would always upgrade hydraulics when running any dual disc clutch.
Luke
katman
5.9L CR Performance
Sep 10, 2015 03:34 AM
Turbo67
Jul 25, 2015 02:26 PM
Dozey
Mar 5, 2015 01:49 PM
Amadeus3
Price Quote - Request A Price
Nov 8, 2014 05:22 PM
Wyocumins
Oct 19, 2014 09:34 PM
