Brake Question
Old Apr 17, 2011 | 03:36 PM
zcarmark's Avatar
Default Brake Question
I have replaced master cylinder because my brake pedal wouldnt hold it would drop to the floor..I still have the same problem. Could the new master cylinder be bad?
Old Apr 17, 2011 | 08:50 PM
twinboys's Avatar
Bleed the brakes, check for leaks.
Old Apr 18, 2011 | 12:27 AM
DuramaxDiesel02's Avatar
Default Re: Brake Question
Yes bleed your brakes. What you described is a common symptom of air in the lines.
Sent from my Droid
Old Apr 18, 2011 | 12:48 AM
zcarmark's Avatar
i have bleed the brakes 3 times, no air
Old May 4, 2011 | 12:48 PM
Seventhree's Avatar
i just replaced the master in mine, then the booster(really hard pedal) i belive in mine the rear brake cylinders are leaking, (has an extremely soft pedal) i believe the brake booster is adjustable not sure. what about sitting in a dry parking lot, and pumping the brakes alot then getting out to see if theres fluid anywhere, maybe a bad line, loose connection.? let us know how you make out and good luck!
Hogridenfool
Nov 20, 2017 04:37 PM
weatherby
Aug 31, 2015 08:04 PM
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
yams
Nov 29, 2014 09:25 PM
