93 7.3 non-turbo
Old Apr 12, 2011 | 04:02 PM
93 bighoss's Avatar
Default 93 7.3 non-turbo
I have a 7.3 non-turbo that is acting up. If i let the truck sit it will start back up then die like its out of fuel, i reprime the fuel filter and it runs fine till i turn it off then start all over again. The other thing its doing is if i put it under a load the filter light comes on and it starts to act like its running out of fuel. can someone help i have tried everything i know.
Old Apr 12, 2011 | 04:40 PM
DieselCrawler's Avatar
either your lift pump is going out or you have a clog in your tank. test fuel pressure at the filter head. should be 5-7 psi.
Old Apr 12, 2011 | 04:45 PM
93 bighoss's Avatar
I will try it, all my problems started when i changed my filter with a house brand and come to find out the filler holes for the injection pump were to small starving the pump.
GarrettEvan
Jan 30, 2016 05:39 PM
honda89
Oct 17, 2015 01:08 PM
fivo2fst4u
Jul 2, 2015 06:20 PM
JSATCT860
10
Jun 26, 2015 12:13 AM
tumble72
8
Nov 27, 2014 10:31 PM
