HPOP
Old Apr 11, 2011 | 04:15 AM
forddually's Avatar
Question HPOP
Hi,new member, I replaced my the non-repairable plug on my 95psd,now i can not get it started,resivour is full,crank case is full,full of fuel,g/p's work,block heater plugged in,if i
spray fuel into intake truck runs,batteries are good, unhooked ICP to fool PCM.
I think i missed something,but what it is i do not know yet, about 200rpm while cranking
oil pressure comes right up. any ideas would be appreciated,thank's
Old Apr 11, 2011 | 10:23 AM
95powersmoker's Avatar
Does it stay running if you hit it with ether?
Old Apr 11, 2011 | 01:50 PM
CSIPSD's Avatar
No more starter fluid!!!!
No NO NO...
Get a scan tool and check the ICP Pressure and duty cycle. Without 500psi, the truck will not run.
Old Apr 12, 2011 | 09:55 PM
OceanDiesel's Avatar
With doing all that you may have a good amount of air still in the system
Old Apr 12, 2011 | 11:29 PM
forddually's Avatar
Default HPOP
Hi, we are taking it to a garage,then maybe a junk yard,the sick part about it is i drove the home after losing a large amount of oil,getting oil at cranking speed,200+ on tach.
Old Apr 13, 2011 | 09:58 PM
You're giving up already?
Old Apr 13, 2011 | 10:44 PM
CSIPSD's Avatar
You don't know what you have...Just because its cranking over does not mean the IPR is not clogged or broken.
You need to get a scanner on it, check the ICP pressure and duty cycle.
Bet money you are getting about 200psi at 70% duty cycle...
Old Apr 13, 2011 | 11:48 PM
forddually's Avatar
Default HPOP
Well took it to a garage they said HPOP was toast and maybe ICP, wanted about $1700.00 to
fix,brought truck home will buy a pump and change it ourselves. Can get a pump from shop i have dealt with before,pump is $562.00 instead of $921.00 from ford,the shop that did the scan said the ICP may or may not be bad.
Pulled plugs on head to suck as much old as possible.
The truck has 267,000 miles on it.
Old Apr 13, 2011 | 11:53 PM
Make sure it has the Anti-drain check valve since your truck is a 95... They had a newer version in the 96-97 models... You HAVE to get one specific to the 95 truck.
Old Apr 14, 2011 | 12:41 AM
forddually's Avatar
Default HPOP
THANKS will check with supplier.What should i be looking for to tell if i have the right pump if i
can not catch supplier before he ships it,thanks
