Head Gaskets
Old Apr 1, 2011 | 11:28 PM
chrisf97305's Avatar
Default Head Gaskets
I am going to remove my heads to install new valve springs and to inspect the top end of the engine.
Here is my question Which head gaskets are the best.
Ford, they want $120 each for them
International, they want $95 each
Then I went to the local parts store and asked for Fle-Pro and they were only $28 a set.
What gives, With pushing between 60 to 70 PSI of boost which head gasket do I want to run?? Don't much care how much as long as they last.
Can any one shed any light on this??
Old Apr 1, 2011 | 11:36 PM
BIG NIG's Avatar
i would go with the International, i will ask around and see what i can find out
Old Apr 2, 2011 | 12:16 AM
95powersmoker's Avatar
Black Onyx gaskets is the brand I'm thinking of...
Old Apr 2, 2011 | 09:18 AM
CSIPSD's Avatar
60-70psi is about 10-20 psi over the limit I would go with stock head gaskets...
You need to give the gaskets several hundred miles to "seal" before you start pushing it.
60psi is close to where I would be looking at fire rings.
Old Apr 2, 2011 | 02:57 PM
I am going to set my wast gates to about 50psi. If I can ease into it then the wast gates will hold the boost at 50, If I just jump on it thats when I have seen bost to the 60psi mark.
I was not going to install fire rings untill I plain on running over 70psi of boost. I don't want to do that untill I can install my other turbos. Thats when I will fire ring the heads and other needed mods.
Old Apr 2, 2011 | 03:58 PM
Farmboy 2.0's Avatar
Hows the Truck running with the new setup Chris?
Old Apr 2, 2011 | 05:44 PM
So far its running great. With out head studs or heavy valve springs installed yet I really have not pushed it.
I hope to have it ready for the dyno by the end of the month. Will post #'s when I get them.
Old Apr 2, 2011 | 08:04 PM
Sweet deal!! You gonna come up to dj's test and tune again?
Old Apr 2, 2011 | 09:09 PM
The pull in Redmond is the same day. Its a night pull, going to be a blast. Would love to pull at DJ's to see what will work but cant be at 2 places at the same time.
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Vmason
Jan 21, 2015 11:33 PM
Adam65
Jan 9, 2015 11:50 PM
Hardcorefx4
Oct 6, 2014 07:47 PM
