Marinco Block Heater Plug Mod
Old Apr 1, 2011 | 10:05 PM
CSIPSD's Avatar
Default Marinco Block Heater Plug Mod
This quick and cheap modification makes it easier to plug and unplug your diesel for those cold mornings. This modification allows for one-handed connection/disconnect in a better location. It's really waterproof, so it won't get corroded.
This article is written for 99+ Super Duties. The procedure would be the same for the 94-97 trucks, only the mounting location would be different.
Time Required
About 30-60 minutes
Items needed:
Marinco onboard charger outlet - about $16 from your local boating supply store (or BoatersWorld.com for you landlubbers)
Silicon seal
Zip ties
Tools needed:
Drill with 1 7/8" hole saw (or smaller bit and sanding drum, saber saw, etc)
Knife
Pencil
Channel locks
Multi-meter (optional)
Installation:
1.Locate the stock plug behind the drivers-side tow hook.
2.The plug's cord runs through a plastic sheath that is taped to two plastic hangers on the back of the bumper and zip-tied to itself. Remove the tape and the zip tie. This part isn't easy but persistence pays off.
3.Locate a spot to mount the outlet on the plastic trim below the bumper near the driver's side wheel. Be sure there is no metal or other interferences behind. While there are other places to mount the outlet (there's about 2' of extra cord), I picked this one to avoid cutting through metal or chrome and so it's easy to see if the cord is still plugged in when getting in the truck. Some other ideas for mounting the plug (which will require more tools and material):
Behind a custom front license plate
Outboard of the tow hooks
In the rear bumper
4.Drill the hole.
5.Hold the plug with the ground terminal up and cut off the stock plug. Note which wire is on which side to ensure the correct polarity on the new outlet.
6.Remove the threaded locking ring and rear boot from the outlet.
7.Pass the cord through these items.
8.Run the cord through the new hole in the bumper.
9.Separate and strip the wire according to the outlet's directions.
10.Install the wires into the outlet and tighten the terminals.
11.Insert the outlet in the hole. Be sure to orient the ground terminal up.
12.Tighten the locking ring with the channel locks and slide on the rear boot.
13.Seal around both sides of the waterproof boot with the silicon seal.
14.Fasten the extra cord with the zip ties.
15.Grab a cold one and admire your work.
Finished Block Heater Plug Mod
It blends well with the stock bumper color
I'm going to do this mod this weekend if I can find the part needed. I will follow up with some new pictures. This was posted on the diesel stop about 8 years or more ago and I wanted to bring it up to date!
Old Apr 4, 2011 | 11:05 AM
jakobengland's Avatar
hell yea looks great
Old May 31, 2011 | 07:59 PM
redneckpipeliner's Avatar
Awesome, gonna have to do this one as well. I think I will run a plug in the front bumper and one in the back as well.
Old May 31, 2011 | 08:30 PM
dbranson1's Avatar
Nice little upgrade, I like that. I will do that and install a glow plug warning light this week as well.
ramrunner01
Feb 25, 2015 11:14 PM
chris_fininzio
Jan 7, 2015 03:19 PM
94_12v
Jan 4, 2015 10:37 PM
bikernut
Audio Equipment/Electrical
Dec 18, 2014 03:30 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
