trani cooler tube?
Old Apr 1, 2011 | 12:10 AM
bowtech's Avatar
Default trani cooler tube?
what are the two tubes that run from trani towards the front of truck there are two side by side that run along oil pan. well the one on right (looking at under truck towards front) rubbed on one of the bolts on pan and got hole tried the ol j b weld and epoxy putty but still leak. where can i find one and how much?
no one knows?
Old Apr 1, 2011 | 08:52 AM
young gun's Avatar
they prolly are trans coler lines. and oil pan you should be able to get at advacne or napa or whatever is around you. you might have to pull the trans to change it.
Old Apr 1, 2011 | 05:32 PM
bowtech's Avatar
they are on out side of trani why would i have to pull trani to change it?
Old Apr 2, 2011 | 03:37 PM
young gun's Avatar
didnt you say a bolt rubed the pan and put a whole in it?? or are you talking the trans pan?
Old Apr 4, 2011 | 10:34 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Those lines are your transmission cooler lines. They can be remover with the transmission still in the truck.
Old Apr 4, 2011 | 10:45 AM
daveO's Avatar
I think he's saying a bolt from the pan rubbed a hole in the trans cooler line.
Also, it looks like rockauto.com has what you need.
Old Apr 4, 2011 | 12:26 PM
young gun's Avatar
i know the lines go outside the trans. but i was assuming they run along the engine oil pan and to pull that pan you might have to pull the trans. but the lines are easy and you should be able to get them at advance.
Crabber0001
6.0L Performance
Aug 4, 2015 12:30 PM
tim12valve
May 6, 2015 10:40 PM
Bighouse
Apr 9, 2015 06:51 PM
mcompton1973
Feb 11, 2015 12:00 PM
bypass-21
Dec 15, 2014 08:52 AM
