'97 cummins injector pump
Old Mar 31, 2011 | 04:26 PM
12vkoalroller's Avatar
Default '97 cummins injector pump
hey some people have told me that increasing my injector pump timing by 17 degrees will help with fuel efficiency and power. is this true and how do i even begin to do this??
Old Apr 14, 2011 | 02:54 AM
EasternAggie's Avatar
Post this in the 12v Cummins area and you'll probably have more luck.
Also run some searches and you should be able to find some informative threads on this. I dont know if I would go to 17 degrees with stock head bolts, 15.5 to 16 is probably the max until you upgrade head bolts or put in studs, because when you increase timing, cylinder pressure increases. Check this out too:
Diesel Timing
Old Apr 14, 2011 | 04:31 AM
Julin's Avatar
Accoriding to my knowledge 14 is the maximum.. i could be wrong too hey eastern can you explain me more about the 12v Cummins as i lack the knowledge . Pickup trucks
Old Apr 14, 2011 | 09:15 AM
1SlowCTD's Avatar
Julin, we typically run either 16* or 18* on 12V's with stock head bolts. Timing choice willl depend on the mods you are wanting to do and how much money you want to spend down the road.
What kind of information are you looking for?
Old Apr 14, 2011 | 01:30 PM
Originally Posted by Julin
Accoriding to my knowledge 14 is the maximum.. i could be wrong too hey eastern can you explain me more about the 12v Cummins as i lack the knowledge.[/URL]
What do you want to know?
I can see 16* but I would think you would be flirting pretty heavy with the head gasket with 18*
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
