Auto trans
Old Mar 31, 2011 | 12:32 PM
shorty2tall's Avatar
Default Auto trans
Ok so I've been thinking how nice it would be to have that extra gear and was wondering is there any 5 or 6 speed autos that would swap easy with a 4r100? Like maybe a 5r110? Or an Allison? Just a thought and I hate where the rpm's are at 75
Old Mar 31, 2011 | 12:50 PM
CSIPSD's Avatar
With the right adapters about anything will bolt up, but you will need a stand alone tranny controler...
Should set you back about 7-8k for a properly done set up...
Or you can go with a Gear Vendors... about 3k...
Or you can throw a set of smaller gears in the axles... about $1800
or you can throw a bigger set of tires on...
Old Mar 31, 2011 | 12:56 PM
95powersmoker's Avatar
Slow down and the rpms will drop...
In all seriousness, 2300rpm at 75 isn't bad, I turn 2500... Step up a tire size and see what that does for you... It's going to be expensive if you go trying to put a completely different transmission in there...
Old Mar 31, 2011 | 04:22 PM
Lange503's Avatar
i have thought about the exact same thing, i'm going to try to bump my tire size up to a 35 or 36, and if that fails i think i'll just buck up and get that gear vendor, i've always wanted one, think they are really cool, just can't spend the 3k on it.... just yet
Old Apr 1, 2011 | 03:21 AM
Default Auto trans
I would slow down but that's what highway speeds are around here 75 and thinks guys dot the ideas first I need bigger tires cuz the guy before me put smaller tires for better gearing he pulled alot and heavy
DieselDan_5.9
Jul 30, 2015 07:05 AM
Beau_Jacques
Jun 26, 2015 12:17 PM
kydieseltech
May 28, 2015 05:00 AM
apehangerjoe
Mar 26, 2015 03:01 AM
countryboy040993
22
Nov 12, 2014 11:25 AM
