turbo ex elbow ??
Old Mar 29, 2011 | 10:23 PM
oldblues's Avatar
Question turbo ex elbow ??
hi
is there a elbow that bolts up to the hx35 turbo to connect directly to a 4 in ex pipe ?
i have a 4 in ex system but the turbo elbow is only 3 in so pipe is necked down there .
egt are a little higher than i like when towing hills in my area so i am trying to lower them .
where do i get one ?
how much ?
thank you !
Old Mar 29, 2011 | 11:04 PM
bulldog77's Avatar
Pac brake used to make a 4" elbow for a 12v. It was spendy though.
What kind of boost are seeing? Do you have a boost elbow? If not get a elbow, set it around 30 to 35psi and that should help alittle.
Old Mar 30, 2011 | 12:03 AM
oldblues's Avatar
hi
i got a non adjustable boost elbow with the 10 plate , it has a small orfice and does bring up boost faster than the stock one did .
i have never had it over 24 lbs of boost , maby the orfice is still too large to allow boost to get any higher ?
Old Mar 30, 2011 | 12:30 AM
davo79's Avatar
Make your own get a 4 inch 45 degree pipe elbow cut the ends off the stock one have em welded to the elbow and weld the elbow to the down pipe
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
